Convert and scale a composite or S-video signal to work with a VGA monitor. This composite/S-video to VGA video converter scales and converts composite video, s-video, and YCbCr (RGB) video to VGA/HDTV - a simple solution for connecting non-VGA/HDTV enabled equipment to VGA or HDTV display devices like CRT monitors, VGA projectors, LCD displays and plasma displays.
The video converter automatically detects your source's input resolution and allows you to customize its output resolution and refresh rate through an easy to use on-screen-display menu - providing a convenient, easy-to-use way to get the most from your HD display.
