Connect an HDMI device/computer to a VGA monitor or projector, with this slim adapter ideal for laptops/Ultrabooks. The HD2VGAMICRO HDMI to VGA converter lets you connect an HDMI output from your Ultrabook, Chromebook or laptop computer to a VGA monitor or projector.
With no external power adapter required, and a small form factor design, this portable HDMI to VGA adapter is a great accessory to have on-hand in your laptop carrying case. Plus, this easy-to-use converter supports plug-and-play installation, which speeds up installation time eliminates hassle.
The converter delivers maximum video quality, with support for resolutions up to 1920x1200/1080p - a convenient solution for boosting productivity by extending your computer's desktop onto to a secondary monitor.
