Maximize your work space by wall-mounting your CPU for easy access. This adjustable CPU mount is an excellent solution both to save space and extend the life of your equipment. Hanging your computer tower on the wall can help to reduce internal contamination from dust and dirt.
This computer wall mount frees up your floor and desk space, so that you can focus on what's important. The heavy-duty black metal frame is strong and dependable, ensuring your computer is securely fastened.
The adjustable base on the CPU wall mount makes it easy to fit a variety of computers, from 4.8" to 8.3" (122 to 212 mm) in width,. It can hold up to 22 lb. (10 kg). The adjustable straps will ensure your computer is secure.
The open frame design of the CPU mount allows unrestricted access to your computer.
Get up and running quickly. The CPU wall mount is easy to mount, and it comes with all the required hardware and an instruction manual to make installation simple. It mounts easily to walls or other sturdy vertical surfaces.
