Add 7 external, USB 3.0 ports to a computer from a single USB connection. The ST7300USB3B USB 3.0 Hub lets you add seven external USB 3.0 ports to a computer from a single USB 3.0 host connection.
Offering data transfer rates up to 5 Gbps, the USB hub meets SuperSpeed USB 3.0 specifications and is backward compatible with USB 2.0 and 1.x devices.
Designed for easy port access when connecting or disconnecting devices, the hub features one-sided port orientation, with current overload detection and protection across all seven ports. The hub supports Plug-and-Play and Hot-Swap technologies, letting you switch and operate your connected devices without having to power down the host computer.
The USB hub is bus powered for use in environments where a power outlet may be unavailable, but is perfect for high-power USB devices when used with the included optional power adapter.
StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/MIn Stock£7.60 |
StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/MIn Stock£4.79 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 HubIn Stock£74.07 |
StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/MIn Stock£5.12 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP SupportIn Stock£22.95 |
StarTech.com 3m USB 3.0 Active Extension Cable - M/FIn Stock£56.93 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/FIn Stock£58.51 |
StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA PowerIn Stock£41.62 |
StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP SupportIn Stock£17.59 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A)In Stock£42.53 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA PowerIn Stock£21.47 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – BlackIn Stock£38.18 |
