100% COPPER WIRING: The CAT6a Ethernet cables are built with 100% copper wiring to prevent weak power delivery and equipment damage, compared to copper-clad aluminum wire cables
QUALITY PERFORMANCE: Built for high performance, each CAT6a patch cable features 26 AWG copper wiring and is tested to comply with ANSI/TIA 568 C.2 CAT6a requirements
EASY INSTALLATION: The 7.5 m network cords feature snagless connectors and molded boots to protect the RJ-45 clips from cable damage during installations and to ensure a secure network connection
26 AWG WIRE: All shielded CAT6a STP cables are built with 26 AWG wiring to ensure peak performance for your demanding Ethernet applications
