Just because your motherboard has a 24-pin ATX connector, it doesn't mean you have to pay for an expensive 24-pin ATX power supply. This adapter cable turns your power supply's 20-pin male ATX connector into the 24-pin male ATX connector needed by high-end motherboards. This reliable power adapter is backed by our lifetime warranty.
- Eiminates the need to purchase an expensive power supply with 24-pin power connector to replace your existing 20-pin power supply
- StarTech.com's lifetime warranty
- StarTech.com's adapter cable converts your existing standard 20-pin ATX power supply to work as a 24-pin ATX power supply
Customer reviews
Write a review for the StarTech.com 6in 20 Pin ATX Power Supply to 24 Pin Motherboard Adapter here!
description wrong
By
andy.
Posted
22/11/2006
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
