Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. This 2-meter (6-foot) angled Lightning cable is great for connecting your mounted mobile devices. You can position it as needed to accommodate your fixed-in-place iPad or iPhone.
Wherever your iPad or iPhone is mounted, this cable provides the flexibility to suit your installation. With an angled Lightning connector, you can position the cable to the left or right of your mobile device in either portrait or landscape mode, without having to worry about straining the connection port.
At two meters (six feet) in length, this convenient cable provides full charging power even at a longer connection distance than most. So, you won't have to endure slow charge times, even when your iPad or iPhone is mounted to a desk, a wall or in your car.
The angled connector positions the cable in such a way that it's easy to access your iPad or iPhone in either portrait or landscape mode, even while charging. Now, you can text, work or game without the cable getting in the way.
The USBLT2MWR Lightning cable is Apple MFi certified.
