DVI Adapter Cable Multi-Monitor Solution Plug & Play Connectivity Multi-Pack. This 10 pack of DisplayPort to DVI cables lets you connect your DP enabled devices to DVI monitors, TVs or projectors from 6 feet (1.8 meters) away, offering a convenient, clutter-free connection. The bulk-pack option provides you with an efficient solution for multiple implementations.
Crystal-Clear Picture Quality
This DP to DVI cable provides high bandwidth video transmissions, supporting monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p. The adapter cable takes full advantage of your DVI capable display while harnessing the video capabilities built into your DisplayPort connection to deliver every detail in stunning high-definition.
Simplified Installation
At 6 ft. (1.8 m) in length, this DVI converter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. As well, the cable is easy to use, and requires no additional software or drivers, supporting a true plug-and-play set up.
Works with Your Existing DVI Displays
This DisplayPort (male) to DVI (male) cable makes your DP computer fully compatible with existing DVI monitors or displays in your home or around the office. You can use the cable to either connect to a DVI display or add an additional monitor to your workstation, helping to boost your productivity.
DP2DVIMM6X10 is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: This is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
