The SVUSBVGA6 6-foot 2-in-1 USB KVM cable is specifically designed to work with any of the StarTech.com VGA USB KVM switches, helping to reduce tangles while maintaining excellent connectivity and performance.
To reduce clutter and optimize cable management efficiency, this professional grade USB KVM cable features an ultra-thin design that combines VGA and USB connectors into a single cable, making it ideal for connecting KVM switches inside a cabinet.
This high-performance 2-in-1 cable provides excellent video quality even for applications requiring high resolution performance.
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSDIn Stock£396.55 |
StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSDIn Stock£205.44 |
StarTech.com 4 Port USB VGA IP KVM Switch with Virtual MediaIn Stock£682.46 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSDIn Stock£446.11 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included)In Stock£272.65 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and CablesIn Stock£465.66 |
StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSDIn Stock£146.81 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSDIn Stock£236.39 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and CablesIn Stock£257.93 |
StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM CableIn Stock£9.75 |
StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM CableIn Stock£6.74 |
