Connect your DVI monitor to a DisplayPort-equipped computer using a single cable.
The DP2DVI2MM6 DisplayPort to DVI Cable lets you connect a DVI monitor to a DisplayPort video card/source. Providing a connection distance of 6ft, the adapter cable features a male DVI connector and a male DisplayPort connector, allowing you to make a direct video card-to-display connection, as opposed to having to use a separate DVI cable and DisplayPort adapter, or vice versa.
The cable offers high quality construction and supports high bandwidth video transmissions that help ensure optimal monitor resolutions (up to 1920x1200) or HDTV resolutions up to 1080p.
The DP2DVI2MM6 6-foot adapter cable offers a convenient and cost-effective solution for taking full advantage of the capability of your DVI display, without the expense of upgrading to a DisplayPort monitor.
DP2DVI2MM6 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
