Create Ultra HD connections between your HDMI -enabled devices, even in tight spaces. The HDMMU6 90° Upward Angled HDMI Monitor Cable is designed to provide crystal clear image resolution and is specifically constructed to fit into tight installation spaces.
This high quality cable features a 90° upward-angled plug, which requires only 34mm (1.27") of space to make the video connection.
The design of the upward angle cable connector helps prevent damage to the cable and ensures long-lasting performance by eliminating the need to bend or strain the cable to account for a lack of space.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
