Add 5.1 channel audio to a desktop PC through a low profile PCI slot. This 5 channel PCI sound adapter card is the ideal sound solution for low profile/small form factor PC computers, supporting full-duplex operation with 6 outbound streams and 2 simultaneous input streams.
Offering everything you need to take your multimedia experience to the next level, the 5-channel sound card supports the latest Dolby Digital EX and DTS 5.1 channel DVD soundtracks, and 96Khz/24bit audio playback.
The sound card includes Windows WDM supported drivers, which save both time and hassle, allowing you to add high quality audio in minutes.
Equipped with a low profile bracket, the 5-channel sound card also includes a standard profile (full-height) mounting bracket and is PCI v2.2 compliant, so it can be installed in virtually any PCI-capable PC regardless of the size of the computer case - a cost-effective HTPC (Home Theater PC) solution!
