Power your workflow with a quad-display mini-docking station featuring 140W charging and USB-A peripheral support
This quad-display USB-C mini-dock expands your visual workspace and streamlines connectivity without sacrificing ports or power.
Quad 4K Display Expansion
Turn a single USB-C port into a high-performance workstation by connecting up to four 4K 60Hz DisplayPort monitors. Ideal for multitasking across large desktops, even on systems with limited GPU or native video output capabilities.
Power and Connectivity Without Compromise
140W power delivery passthrough charges your laptop, while the USB-A 2.0 port supports essential peripherals like a mouse, keyboard, or wireless dongle. This helps you stay productive with no compromise on available ports.
Plug-and-Play
DisplayLink drivers install automatically on most Windows and ChromeOS systems, reducing setup time and simplifying large scale IT deployments. For macOS devices, a manual driver installation is required.
Ideal for Hybrid Workflows
Designed for IT, finance, engineering, and education use, this compact, travel-ready workspace adapter enables easy transitions between home, office, and on-the-go setups. Its durable design and broad compatibility make it the perfect choice for professionals who require consistent performance wherever they work.
