            Discover the StarTech.com 3m White USB-C Charging Cable, a versatile and durable solution for all your charging needs. This cable supports Power Delivery 2.0 and USB Power Delivery up to 60 W, allowing for fast and efficient charging of your devices. With a data transfer rate of 480 Mbps, it also facilitates quick syncing of files, photos, and videos. The cable is designed for longevity, featuring a polyamide housing, a minimum bend radius of 8 mm, and a 10,000 insertions lifespan. It also includes EMI protection and aluminum mylar foil with braid shielding material to protect against electromagnetic interference, ensuring a stable and reliable connection. Whether at home, in the office, or on-the-go, this USB-C cable is the perfect choice for those seeking a high-quality, durable charging solution.
