Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one GbE port. Here's a must-have accessory for your USB-C equipped MacBook Pro, Chromebook or laptop. This USB 3.0 hub merges your USB peripheral and RJ45 network connections into a single combination hub. It gives you two vital connection types, with Ethernet and USB Type-A, which are often missing from modern laptops.
This 3-port USB hub features an easy-to-use USB-C connector. USB Type-C connectors are easier to insert than past generations. They're small and reversible, and you can connect the plug with either side facing up.
If your MacBook or laptop is missing the ports you need, this hub can help. USB 3.0 is also known as USB 3.1 Gen 1. The versatile USB 3.0 hub gives you access to not only your USB peripheral devices but also a wired internet connection. It offers a Gigabit Ethernet port, so you can connect to a network in locations where Wi-Fi is unreliable or unavailable.
The stylish USB hub features an attractive white finish.
The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. Its USB-powered design means you don't need to carry a separate power adapter, so you can tuck the USB 3.0 hub neatly into your travel bag.
This hub is perfect for travel, and it takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
The hub's built-in USB-C cable makes connections easy, and you don't need to carry a separate cable to attach the hub to your laptop.
StarTech.com 6 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 6ft Patch CordIn Stock£2.76 |
StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethernet SwitchIn Stock£16.56 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ CableIn Stock£36.09 |
StarTech.com 4 Port USB 3.0 Hub - USB-C HubIn Stock£26.24 |
StarTech.com 3Pt Portable USB 3.0 Hub + GbEIn Stock£30.89 |
StarTech.com USB-C to Gigabit AdapterIn Stock£33.18 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - DesktopIn Stock£43.47 |
StarTech.com 5 Port USB 3.1 (10Gbps) CardIn Stock£41.31 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - WhiteIn Stock£30.50 |
