Type: | Network / USB adapter |
Compatibility: | PC |
Interface: | PCI Express 2.0 x1 |
Quicklinx: | BCN8WS00 |
Mfr#: | PEXUSB3S3GE |
Running low on expansion slots? Merge USB 3.0 and GbE into a single PCIe combo card. This PCIe USB 3.0 card couples your peripheral and network connections into a single, scalable solution.
By combining three USB 3.0 ports and one RJ45 port onto a single card, you only need a single PCIe slot for installation, which lets you free up space for other add-ons or upgrades and get more out of your desktop or server.
If you have separate cards for your USB and network connections, this versatile card overcomes the aggravation of running out of PCIe slots while helping to reduce clutter inside your PC.
This dual-purpose card is perfect for building or upgrading your computer. It helps you save money by avoiding the additional costs of purchasing separate USB 3.0 and Gigabit Ethernet adapters.
You can rest assured this card will fit in your small form-factor system, if needed. It features a dual-profile design that makes it easy to install in either standard or low-profile cases.
The combo card makes it easy to connect peripherals such as your external hard drives or mobile devices. Plus, it's backward compatible with USB 2.0 and 1.x, so you won't have to replace all of your existing USB devices.
Functioning as a network adapter, the card delivers wired network access in locations where Wi-Fi is unavailable or unreliable.
Support for advanced features such as jumbo frames and VLAN tagging means you can optimize network traffic as needed.
This high-performance SuperSpeed USB 3.0 adapter card supports data transfer rates up to 5 Gbps and is enhanced with UASP support, which can perform ~70% faster read speed and 40% faster write speed over traditional USB 3.0.
StarTech.com 6in 4 Pin Molex to SATA Power Cable AdapterIn Stock£2.96 |
StarTech.com 25 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch CableIn Stock£7.22 |
StarTech.com 10 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 10ft Patch CordIn Stock£3.23 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - WhiteIn Stock£36.03 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 PowerIn Stock£18.76 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A)In Stock£42.53 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA PowerIn Stock£21.47 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ CableIn Stock£36.09 |
StarTech.com USB 3.0 IDE / SATA EnclosureIn Stock£21.20 |
StarTech.com 7 Port USB 3.0 Hub DesktopIn Stock£48.61 |
StarTech.com 7 Port PCIe USB 3.0 CardIn Stock£49.47 |
StarTech.com 4 Port PCIe USB 3.0 CardIn Stock£25.36 |
