Add 2 external and 1 internal FireWire400 port to any computer with a low profile PCI slot. This 3 Port PCI Low-Profile/Half-Height 1394a FireWire Adapter Card turns a motherboard PCI slot into two external IEEE 1394a FireWire slots (1x6-pin, 1x4-pin), and provides an internal (6-pin) FireWire port that can be used in place of the external 6-pin connector - a cost-effective solution that lets you connect any FireWire 400 device to your desktop computer.
Compatible with either Mac or PC computers, the 1394a FireWire card can be installed in small/micro form factor computer cases, and includes both standard and low profile/half-height brackets for easy installation.
A practical solution for connecting iPods, MP3 players, portable drives, digital camcorders and more to your desktop computer, the FireWire 400 adapter card supports hot-swappable connectivity, allowing you to plug, unplug, and swap your FireWire peripherals with ease.
A versatile FireWire video editing solution, the adapter card can be installed in a PCI 5V or PCI-x 3.3V slot.
Customer reviews
Write a review for the StarTech.com 3 Port PCI Low Profile 1394a FireWire Adapter Card here!
Great Firewire card for slimline desktops
By
Grumpy.
Posted
16/07/2007
Vista 64 plug & play
By
Sam.
Posted
02/12/2008
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
