Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort monitor and a DisplayPort source. The DP2MDPMF3 3ft DisplayPort to Mini DisplayPort 1.2 Cable Adapter turns a Mini DP male connector into a regular DisplayPort male connector, making it easy to connect a Mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Toshiba etc.).
The DP to Mini DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
StarTech.com DisplayPort to DVI Video Adapter ConverterIn Stock£15.63 |
StarTech.com DisplayPort to HDMI Video Adapter ConverterIn Stock£15.05 |
StarTech.com DisplayPort DVI Video Adapter ConverterIn Stock£13.69 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/MIn Stock£33.86 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/MIn Stock£27.03 |
StarTech.com 6 ft DisplayPort Video Extension Cable - M/FIn Stock£22.03 |
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4kIn Stock£7.46 |
StarTech.com Mini DisplayPort to DVI Video Adapter ConverterIn Stock£10.55 |
StarTech.com Mini DisplayPort to VGA Video Adapter ConverterIn Stock£19.21 |
StarTech.com Mini DisplayPort to HDMI Video Adapter ConverterIn Stock£9.92 |
StarTech.com DisplayPort to DVI Video Adapter ConverterIn Stock£10.18 |
StarTech.com 3ft DisplayPort Panel Mount Cable - F/MIn Stock£11.01 |
StarTech.com 3 ft DisplayPort to Mini DisplayPort 1.2 Video Cable Adapter M/F - DisplayPort 4kIn Stock£8.24 |
