Turn a 3.5" SATA Hard Drive into a UASP-supported USB 3.0 External Hard Drive. The S3510BMU33 Black USB 3.0 Hard Drive Enclosure with UASP lets you connect a 3.5in SATA III hard drive (HDD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 3.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD enclosure is compatible with virtually any 3.5in SATA hard drive, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0/SATA III enclosure features high quality aluminum construction, ensuring durability.
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDDIn Stock£29.00 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 ExternalIn Stock£24.13 |
StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP SupportIn Stock£30.22 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP SupportIn Stock£22.95 |
StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA PowerIn Stock£41.62 |
StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 PowerIn Stock£49.19 |
StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP SupportIn Stock£17.59 |
StarTech.com 2 Port SuperSpeed Mini PCI Express USB 3.0 Adapter Card w/ Bracket Kit and UASP SupportIn Stock£38.08 |
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6In Stock£16.60 |
StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASPIn Stock£15.54 |
StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 GbpsIn Stock£33.73 |
StarTech.com 3.5in Silver USB 3.0 External SATA III Hard Drive Enclosure with UASPIn Stock£30.29 |
