The GCAUD3535FF Audio Cable Adapter/Audio Coupler features two 3.5mm audio female connectors, providing a cost-effective way to combine two standard 3.5mm stereo headphone cables or convert a standard audio cable into an extension cable.
The 3.5mm Female to Female Coupler features gold plated connectors, ensuring a high-quality connection that maintains the purity of the audio signal for clear, uninterrupted sound.
Versatile audio coupling
Designed to extend the reach of your existing audio cable, this coupler seamlessly connects two male 3.5mm audio cables together, making it ideal for a wide range of audio applications.
Durable design
Constructed with a PVC jacket material, the coupler is built to withstand regular use while ensuring flexibility and protection for the internal connectors, offering both durability and reliability.
