Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. The USB2ADC2MR USB cable for iPhone, iPod and iPad (2m) features a right-angled Apple (30-pin) Dock Connector which positions the cable in such a way that it allows you to easily access your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 2m Left Angle Apple 30-pin Dock Connector to USB Cable (USB2ADC2ML), which provides the same convenience as this right-angled cable, but allows you to connect to your iPhone, iPod or iPad from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
