This 25ft Cross Wired Serial/Null Modem Cable features two DB9 female connectors, allowing you to connect a 9-pin serial port to a serial port, or transfer files from PC to PC via serial connection.
With a length of 25 ft, this null modem cable allows for versatile setups, accommodating different arrangements between devices without restriction.
Dual female connectors
The cable is equipped with female 9-pin D-Sub connectors on both ends, ensuring compatibility with various serial devices requiring gender-specific connections.
Enhanced data integrity
Engineered for reliable data transfer, this cable minimizes signal loss and ensures steady communication between devices, proving essential in critical applications.
StarTech.com 25 ft Cross Wired DB9 Serial Null Modem Cable - F/F - 25ft DB9 Null Modem Cable (SCNM9FF25) - null modem cable - 7.6 m
