Add 2 internal SATA 2.0 ports to your desktop computer through a PCI Express expansion slot. This 2 Port PCI Express Internal Serial ATA Controller Card adds two internal SATA II (SATA /300) ports to a computer through simple installation into an available 1x PCI Express slot.
Supporting data transfer speeds of up to 3.0 Gbps, the SATA controller card features Port Multiplier support with command-based switching as well as Native Command Queuing to ensure optimum performance.
Using a native PCI Express single chipset, the internal SATA controller card provides enhanced compatibility, reliability and performance for your external storage needs. The controller card also features Port Multiplier support with command based switching for connecting multiple external hard drives to a host computer through one eSATA connection.
The controller card includes both standard form factor and low profile brackets, allowing you to add SATA capability to virtually any PCI Express enabled computer, regardless of the case form factor.
