The network adapter supports a data transfer rate of 1 Gbps, suitable for high-performance networking requirements.
Versatile connectivity options
With two available RJ-45 ports, this adapter card allows for multiple connections to your network.
Wide temperature tolerance
Operating effectively within a temperature range of 5°C to 70°C ensures stability in various environments.
Comprehensive compatibility
This adapter complies with IEEE standards, ensuring it meets the necessary requirements for effective network integration.
User-friendly installation
The Plug-and-Play feature simplifies setup, allowing quick deployment without complicated configurations.
