The S2510SM12U33 USB 3.0 to SATA hard drive enclosure with UASP enables you to connect a 2.5" SATA hard drive or solid state drive to your computer through an available USB port.
With support for drives up to 12.5 mm in height, and high-capacity SATA I/II/III drives, this versatile USB 3.0 enclosure ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
To maximize performance and better utilize the full potential of your SATA III SSD/HDD the enclosure supports UASP, which allows for transfer speeds up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The USB 3.0 enclosure features a sleek design with high-quality aluminum construction and ventilation, ensuring excellent heat dissipation. The S2510SM12U33 requires no external power adapter to maximize portability.
