This 10-pack of 1U blanking panels can help you to dramatically improve the appearance and airflow of your EIA-310 compliant 19 in. server rack.
These blank rack panels create a clean and professional look by covering empty rack spaces and visible cables, for a more organized server room.
For fast and easy installation, these rack blanks feature a tool-less design that latches onto a standard 19 in. server rack, saving you time and hassle.
The filler panels feature a solid design that helps guide airflow down the back of your rack-mounted equipment, rather than through unused units of rack space. This helps expel any operating heat from your rack-mounted equipment, to keep it running at optimal temperatures.
