Add a high capacity, adjustable depth vented shelf into almost any server rack or cabinet. The ADJSHELFHDV 1U Adjustable Heavy Duty Vented Rack Mount Shelf lets you add a high-capacity, adjustable 1U shelf to virtually any standard 19-inch server rack or cabinet.
This heavy duty rackmount shelf can be adjusted from 19.5in to 38in (mounting depth) to fit your rack, while the vented design improves air flow and help to lower temperatures in the rack. Constructed using 1.2mm SPCC commercial grade cold-rolled steel, providing the ability to hold up to 113kg (250lbs) of equipment - a durable solution for storing large, non-rackmount pieces of equipment, heavy tools or peripherals in your rack or cabinet.
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack CabinetIn Stock£15.93 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kgIn Stock£76.45 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack CabinetsIn Stock£12.71 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack CabinetIn Stock£33.51 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack CabinetIn Stock£14.36 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack CabinetIn Stock£29.51 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack CabinetIn Stock£55.00 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack CabinetIn Stock£58.24 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet ShelfIn Stock£82.96 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kgIn Stock£86.16 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack RailsIn Stock£58.10 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kgIn Stock£63.41 |
