Make Power-over-Ethernet-capable Gigabit network connections. The C6CROSS1MYL Cat6 Crossover Cable (1m) meets or exceeds all Category 6 cable specifications, to ensure reliable Gigabit network connections and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 crossover cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
Constructed of only top quality materials, this Gigabit Crossover Cable delivers reliable performance.
StarTech.com Cat 6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Ethernet crossover cable is constructed with 24 gauge copper wire, to support a broad range of network applications, such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This Cat6 cable offers high quality connectors, comprised of 50-micron gold to deliver optimum conductivity while eliminating signal loss that results from oxidation or corrosion.
