Make a right-angled connection to your SATA drive, for installation in tight spaces. The LSATARND18R1 18-inch Round SATA cable is a high quality SATA 6Gbps cable that features a rounded design to help improve airflow inside a computer or server case by providing less resistance as air passes around the cable, in turn helping to ensure cooling for improved system performance.
The cable features one straight latching SATA connector as well as a right-angled latching SATA connector, for a simple connection to your Serial ATA drive even if space near the drive SATA port is limited, which allows for a more convenient cable positioning inside the computer case. Also, the latching connectors ensure secure connections to SATA hard drives and motherboards that support this feature.
