Wallmount and store your non-rackmount server, networking or AV equipment. The WALLSHELF 17in Deep Vented Equipment Wall Mount Equipment Shelf provides an inexpensive and durable solution for wall mounting any non rackmount equipment in your server room.
An industrial-grade solution, the wall mountable shelf features a solid steel design with 16in spaced mounting holes (for standard wall studs), and supports a total weight capacity of up to 200 lbs (91 kg). For simple cable management, the shelf includes four pre-cut cabling holes with grommets, allowing you to easily route network, power, display or other cabling as needed.
