Connect your system LED panel status lights to your motherboard or hard drive controller, with a 12-inch cable. The IDC2PIN12 Motherboard/HDD LED cable features two 2-pin IDC header connectors, enabling you to connect your system LED panel status lights to your motherboard or hard drive controller.
Offering 12 inches in cable length, the IDC2PIN12 allows for flexible routing of connections as needed within the system case.
