The POESPLT100 10/100 Mbps PoE Power over Ethernet Splitter with 5-12V Output separates the data and power connections received from your Power Sourcing Equipment(PSE) such as a single port PoE injector or a PoE Switch.
At the remote end of your PoE connection, the POESPLT100 gives you a standard DC jack with selectable 5, 7.5, 9 or 12V output and separate Ethernet data connection allowing you to take advantage of power of Ethernet infrastructure, and use a variety of peripherals in places where no wall outlet exists.
