Add a Null Modem RS232 serial port to your laptop or desktop computer through USB. The ICUSB232FTN FTDI USB to Null Modem Serial Adapter Cable (1 port) converts an available USB 1.1 or 2.0 port into an RS232 Null Modem serial DB9 port, solving DCE/DTE conflicts directly, without requiring additional cross-wired serial cables or adapters.
This compact adapter features COM retention, allowing the same COM port value to automatically be re-assigned to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. The integrated FTDI chipset supports additional customization, advanced features, and compatibility not necessarily offered by other solutions.
The USB to Null Modem adapter is compatible with a broad list of operating systems including Windows, Windows CE, Mac OS and Linux, making it easier to integrate into mixed environments.
StarTech.com 6ft Straight Through Serial Cable - DB9 M/FIn Stock£3.53 |
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM RetentionIn Stock£14.62 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM RetentionIn Stock£21.31 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/MIn Stock£10.19 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM RetentionIn Stock£15.18 |
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/MIn Stock£14.99 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical IsolationIn Stock£72.72 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDIIn Stock£16.39 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/FIn Stock£4.07 |
StarTech.com USB to RS232 Serial AdapterIn Stock£10.89 |
