Sync your Micro USB, iPhone, iPod or iPad devices using a single cable. The USB2UBADC1M Apple (30-pin) Dock Connector/Micro USB to USB Combo Cable (0.65m) offers a simple and reliable solution for connecting Micro USB or iOS-enabled mobile digital devices to your computer, for syncing or charging.
For charging your devices and syncing data between your computer and your iPhone /iPad /iPod or Micro USB devices, the cable features a combination Micro USB connector and Dock Connector on one end, and a standard USB male connector on the other, enabling you to connect directly (or through a dock) to a computer USB port. Or, to simply charge the device, connect it to a USB wall outlet power adapter.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other mobile device, you can use this 0.65m 30-pin Dock/Micro USB to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
