The Xperia M4 Aqua phone features a 5-megapixel, super wide-angle front camera so you can fit even more in the shot - you, your companions, and the impressive view. For days that are jam-packed with work or play, you need a smartphone that keeps on going. The Xperia M4 Aqua features a long battery life so you’ll never have to worry about staying out and about. The Xperia M4 Aqua is as durable as it is beautiful. Its great design protects it against water as well as fine dust particles so you’ll never have to put it away ‘just in case’.
