An exceptional listening experience that's tailored just for you. The WF-1000XM4 truly wireless headphones take advanced noise canceling and audio quality to the next level. Made to fit every ear, they offer a personalized experience that adjusts to every situation.
Industry-leading noise cancellation – now even better
Everything in the WF-1000XM4 headphones has been designed from the ground up. Like our new Integrated Processor V1, specially developed by Sony, that cancels more noise than ever, a new driver unit with more performance, noise sensing microphones, and innovative Noise Isolation Earbud Tips with a more stable fit.
High performance dual noise sensor microphones
Two noise sensing microphones per ear – one feed-forward and one feed-back – on the surface of the headphones catch more of the ambient sounds of your surroundings, whether it’s in-flight noise, city traffic or office chatter.
New 6mm driver unit
A newly designed 6mm driver unit, featuring a 20% increase in magnet volume and the high compliance diaphragm, gives you improved performance in low frequencies. It also enhances noise cancelling by generating a high-precision cancellation signal to the low frequency range.
Newly developed Noise Isolation Earbud Tips feature a unique polyurethane foam material. Soft and elastic, it maximises the surface contact area between the earbud tip and the ear canal, eliminating gaps to insulate sound and reduce noise. It also improves adhesion to the ear canal for a more stable fit, making the WF-1000XM4 headphones easy to wear.
Minimising wind noise
Even on windy days you’ll stay totally immersed. Automatic Wind Noise Reduction mode detects when it’s windy and automatically suppresses it.
Hear more of what’s around you
In Ambient Sound mode, the WF-1000XM4 headphones capture more of the sound around you than ever before, which means you get a more natural listening experience and stay connected to your environment.
