Discover the Sony WH-ULT900N headphones, where innovation meets exceptional sound. Engineered with Dual Noise Sensor Technology and Active Noise Canceling, these headphones are designed to provide an immersive audio experience by filtering out ambient noise, allowing you to focus solely on the music. Bluetooth 5.2 technology ensures seamless wireless connectivity, while the option for wired connection via a 3.5 mm jack or USB-C offers flexibility for all your audio needs.
Comfort is key with the WH-ULT900N. The adjustable headband and foldable design make it easy to find the perfect fit and take your music on the go. Full-size ear cups envelop your ears in sound, not pressure, ensuring comfort during extended listening sessions. With smart features like built-in Alexa and Google Assistant, wear detection, and Dynamic Head Tracking, these headphones are not just about listening; they're about enhancing your audio experience in every aspect. Whether you're at home or on the move, the Sony WH-ULT900N headphones are your gateway to a world of sound quality and convenience.
INTRODUCING THE ULT WEAR
With huge, powerful bass, next-level clarity, and seriously impressive noise cancelling, take the ULT POWER SOUND experience, wherever you go.
DESIGNED FOR POWER
Using Sony’s Integrated Processor V1 and high-quality 40mm driver units, ULT WEAR deliver a powerful listening experience, perfect for the bassline obsessives.
HIT THE BUTTON, FEEL THE BASS
Unleash ULT WEAR’s two unique sound modes by pushing the ULT button - Deep Bass adds even more weight to the lower frequencies, while Attack Bass ramps up the energy.
NOISE CANCELLING WITH AMBIENT SOUND
Block out distractions and fully focus on your music with these noise cancelling headphones, or hear your surroundings with Ambient Sound mode.
LISTEN IN COMFORT, AND STYLE
The over ear headphones are designed to be comfortable, even when used for long stretches of time. The compact, durable carry case makes them easy to take anywhere.
CLEAR CALL QUALITY
Featuring Beam Forming Microphones and our Precise Voice Pickup technology, hands-free calls are always easy to understand with ULT WEAR, even when you’re surrounded by noise.
LONG BATTERY LIFE
Enjoy 30-hour battery life when noise cancelling is switched on, or 50 hours when switched off. Quick charging provides 1.5 hours of playback from a 3-minute charge.
EASY CONNECTIVITY
Connect two Bluetooth devices at once with Multipoint Connection. Connecting your wireless headphones to Android/Windows 10 devices is simpler than ever with Fast Pair/Swift Pair.
