Back
Speaker Docks
Sony SRS-BTV25 Bluetooth Wireless Speaker - iPhone/iPad - Black
Quicklinx:
8JBDWS00
Mfr#:
SRSBTV25B.CEK
Back
Marketing description is not available.
360° sound experience
Enjoy a 360° superior circle sound experience for your entire iTunes collection.
Stream music without wires
Effortlessly stream music to the dock speaker from your iPod/iPhone.
Bluetooth
Effortlessly stream music to the speakers from your Bluetooth stereo compatible device such as a smartphone.
Stylish design
Fits perfectly in your living room and smaller spaces, like a kitchen, den, bedroom or other second room.
USB charging
USB port charges your SmartPhone, iPod/iPhone/iPad and Walkman while you listen back.
Sony SRS-BTV25 - speaker - wireless
Speaker
Enclosure Design
Bass reflex
Speaker Type
2-way - active
Continuous Power
13 Watt
Nominal Impedance
4.7 kOhm
Amplifier
Integrated
Bluetooth
Speaker System Details
1 x speaker 13 Watt 6 Ohm
AC 120/230 V
Power Options
USB charging
14.5 cm x 14.5 cm x 14.5 cm
0.5 kg
Speaker
Enclosure Colour
Enclosure Design
Bass reflex
Speaker System
Speaker Type
2-way - active
Continuous Power
13 Watt
Nominal Impedance
4.7 kOhm
Amplifier
Integrated
Bluetooth 2.1 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Controls
Volume, bass boost
Speakers Included
1 x speaker - 2-way - 13 Watt - 6 Ohm - wireless
Driver Details
Speaker: woofer driver - 2.2" , Speaker: tweeter driver - 0.79"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
Power adapter
Power adapter - external
Power Source
AC power adapter
AC 120/230 V
12 Watt
Options
USB charging
14.5 cm
14.5 cm
14.5 cm
0.5 kg
