The high-pressure mercury lamp of 210 W provides a bright and clear projection, ensuring your presentations or movies are vivid and engaging.
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
