The ultra high-pressure mercury lamp with a 210 W capacity ensures your presentations are vivid and bright, even in well-lit rooms. Its high wattage allows for clearer, more impactful visuals, making it an ideal choice for professional settings where clarity is paramount.
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup. Its compatibility ensures a hassle-free installation process, allowing you to upgrade your projector's performance without the need for complex adjustments or technical support.
