This digital voice recorder is super easy to use, and records in high quality stereo sound. The built-in S-Microphone System and a wider recording range provide high sensitivity and less noise. Built-in FM tuner easily catches up on your favorite shows in between recordings. Red and green illuminated LED buttons display rec/play status, at a glance. The recorder easily connects to your PC with USB direct link, simply plug in and share content.
