Feel the sunlight bursting through the trees. The Slim Backlight Drive+ technology directs light where it's needed, filling scenes with extra brightness and deep contrast.
Take a tour of this beautifully styled TV with innovative full array LED backlight and enjoy the best of both worlds - exceptionally detailed pictures in an ultra slim design.
4K HDR Processor X1 Extreme
X1 Extreme shows images and colors as they truly are, the way you want to see them.
X-tended Dynamic Range PRO
Enjoy a beautiful night view, full of dazzling lights and deeper blacks. With up to ten times the contrast of conventional LED TVs, dark scenes are darker and bright scenes brighter.
TRILUMINOS Display
See vivid real world colors all around you.
Designed to keep your focus on the picture
With its ultra slim profile and narrow frame, this TV keeps you focused firmly on your entertainment. Cables stay cleverly hidden at the back and front.
Sony Bravia KD-75XE9405 75" Class (74.5" viewable) LED-backlit LCD TV - 4K
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN, Bluetooth
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
Connect & Share
Screen Mirroring, Wi-Fi Miracast, Photo Sharing Plus
Internet Streaming Services
Google Play, Google Cast, Chromecast, YouView
Connector Type
HDMI input - side , Composite video input - side , Composite video / component video input - side , Audio line-in - side , Audio line-out / headphones / subwoofer - side , 2 x USB - side , LAN - bottom , SPDIF output - side , 3 x HDMI - bottom , USB - bottom
Batteries, IR Blaster
Power adapter
Input Voltage
AC 230V (50 Hz)
Power Consumption Stand by
0.5 Watt
On/off timer, energy save
Dimensions & Weight Details
Panel without stand - 167.3 cm x 6.2 cm x 96.2 cm x 42.8 kg , Panel with stand - 167.3 cm x 32.5 cm x 103.7 cm x 47.6 kg
