Essential Sound
The powerful microphone-free speaker for music and more.
Get rich, room-filling sound with Sonos One SL, and control it with the Sonos app, Apple AirPlay 2, and more.
Brilliant sound for every room
The compact design fits just about any space. Put it on your kitchen countertop or tuck it away on your office bookshelf.
Small but powerful
One SL features two Class-D amplifiers perfectly tuned to its unique acoustic architecture.
Customized sound
Trueplay puts the speaker-tuning capability of recording pros in the palm of your hands to optimize the sound for the room.
Apple AirPlay 2 on Sonos
Stream sound directly from your iPhone or iPad and ask Siri to play Apple Music.
Setup is simple
Go from unboxing to listening in minutes. Just plug in the power cord and open the Sonos app.
Listen in every room
All Sonos speakers and components connect over WiFi so you can create the system you want and expand any time.
One app does it all
Control your system and all your streaming services. Group rooms, quickly add new speakers, and more.
Control at your fingertips
Responsive touch controls on the top of the speaker make it easy to play, pause, skip, and adjust the volume.
Stereo sound with two
Pair with Sonos One or another One SL in the same room for stereo separation and more detailed sound. Use a pair as rear home cinema surrounds with Playbar, Playbase, or Beam.
Introducing Sonos Radio
Enjoy thousands of stations, including live radio and exclusive programming, on your system through the Sonos app.
