The Somfy Outdoor Security Camera lets you scare burglars off with smart motion detection and a siren. The camera also comes with a smart activation function. When you get back home, the system will recognize you and switch itself off, and if you go out again, you'll get a reminder via the app on your smartphone to re-activate the camera. That's convenience for you!
As soon as the camera detects movement, the siren will go off and you'll immediately receive a push message on your smartphone. You can watch live, check the recorded images of 30 seconds and download those images for free.
