Quicklinx: | 7L3BWS00 |
Mfr#: | XS35GTV2 |
The Shuttle Barebone XS35GTV2 is a mini-PC which, thanks to its shape can be easily fitted behind flat panel displays and therefore does not take up any space. Intel's Atom dual core processor and the NM10 Express chipset serve as the energy-saving hardware platform. A high-performance NVIDIA ION graphics card provides streaming 3D and video playback. Thanks to the HDMI connection there is also excellent sound and picture quality. Other front and rear connections include several USB ports, VGA, Gigabit LAN and audio. For wireless communication, WLAN is already integrated. The small casing has room for a card reader, a 2,5" hard disk and optical slimline drive. The XS35GTV2 is passively cooled, and thus virtually noiseless.
Only 38 mm thick, HD-ready, fanless and low power usage
The Shuttle Barebone XS35GTV2 is a Mini-PC in the 1-litre class which, thanks to its shape can be easily fitted behind flat panel displays and therefore does not take up any space. Intel's Atom D525 Dual Core Processor (2x 1.8 GHz) and the NM10 Express chipset serve as the energy-saving hardware platform. A high-performance Next- Generation NVIDIA® ION™ graphics card (ION2) provides streaming 3D and video playback. Thanks to the HDMI connection there is also excellent sound and picture quality. Other front and rear connections include 5 x USB, VGA, Gigabit-LAN and Audio. For wireless communication, WLAN (n) is already integrated. The small casing as room for a card reader, a 2,5" hard disk and optical slimline drive. The XS35GTV2 is 100% passively cooled, and thus virtually noiseless.
Slim and stylish
Designed as a space-saver, this sleek 1.5 litre nettop PC only measures 3.8cm in width. It maximizes space whether it is placed upright using its stylish stand or affixed to the back of a display with the optional VESA mounting kit (PV01). Due to its small size and flexible design, this practical nettop offers exceptional functionality and is well-suited for home users, small offices, reception areas, classrooms, libraries, showrooms, call centres, public institutions and more.
Fanless and quiet
The Shuttle Barebone XS35GTV2 comes totally fanless making it perfect to be used in noise-sensitive environments such as living rooms, hospitals, libraries etc. As an additional benefit, fanless cases rarely gather dust on the inside and stay cleaner than others. So it's not only quiet and low in energy use, but also dust-free and virtually maintenance free.
The Atom processor integrates the memory controller
Shuttle XS35GTV2 is equipped with Intels Atom processor D525 (1.8GHz, codenamed Pineview-D). It comes with both the memory controller and graphics core on-die which helps to keep heat dissipation and memory latency low. The CPU is connected to the Southbridge NM10, codenamed Tiger Point.
Dual Core. Do more.
Shuttle always uses the dual-core variant of Intel's Atom processors and thus integrates the Atom D525. This boosts the system performance significantly with particular regards to multi-threaded applications.
Next Generation ION graphics
Even with the small size, the Shuttle Barebone XS35GTV2 is equipped with NVIDIA's Next Generation ION graphics for a power-packing slim PC that's unmatchable in size and performance - and is made for more than just entertainment. Key benefits are:
Feature Highlights
