| Quicklinx: | B09YWS00 |
| Mfr#: | XH97V |
The Shuttle XH97V, with its Intel H97 Chipset and 4th and 5th generation of Intel Core processor support, delivers power and performance needed in the most demanding work environment. The 3.5 Liter chassis enables a balanced platform for creating a solution that's as powerful - or energy-efficient - as you want it to be to your office and business. The XH97V adds a new dimension to your video experience with built-in features included in 4th and 5th generation of Intel processors as well as new built-in 3D visuals, graphics, 4K ultra HD, and Intel WiDi which allows users to view content on an Intel WiDi-enabled TV Screen. The XH97V is specially designed to be business friendly with increased manageability and security. It supports Intel Small Business Advantage (Intel SBA) that allows users to monitor and maintain PC security, and helps prevent theft by blocking unwanted USB devices from being recognized on your PC. The XH97V also supports Intel Device Protection Technology with Boot Guard that helps block viruses and other malicious software from infecting your PC. With these security features in place, you can have a peace of mind knowing that your data is well-protected.
