Securifi Almond DSL Wi-Fi Ethernet LAN Black ALM-BLK-EU
A Router for Humans
Easy Setup Touchscreen WiFi Router.
You will be online within seconds.
Just connect your Cable/DSL modem and follow the on screen instructions.
Pre-configured security.
Prevent intruders from accessing your wireless data.
Up to 300Mbps using 802.11n MIMO tech.
Connect up to 50 users at a time.
Compatible with older 802.11bg devices.
Everything you need is just a finger tap away.
The user interface is a quantum leap over existing routers.
