Seagate manufactures hard drives that specifically address the needs of the hyperscale storage market. As the flagship of the Seagate X class, the Exos X16 enterprise hard drives are the highest-capacity hard drives in the fleet.
Engineered with a helium sealed-drive design and a remarkable MTBF of 2,500,000 hours, this hard drive promises reliability and longevity, ensuring your data's safety over extended periods.
Efficient performance
Boasts an impressive internal data rate of 261 MBps and a high capacity of 16 TB, coupled with advanced features like PowerBalance and PowerChoice, optimizing performance while maintaining energy efficiency.
Enhanced data integrity
Incorporates T10 Data Integrity Field (DIF) and Super Parity features, significantly reducing the risk of data corruption and ensuring the integrity of your data at all times.
Seagate Exos X16 ST16000NM002G - hard drive - 16 TB - SAS 12Gb/s
Hard drive - internal
16 TB
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
PowerChoice, Dual Port, Low Halogen, Super Parity, Hot-Plug Support, T10 Data Integrity Field (DIF), PowerBalance, advanced format 512e, advanced format 4Kn, Organic Solderability Preservative, Seagate Fast Format, Helium Sealed-Drive Design
101.85 mm x 147 mm x 26.11 mm
670 g
5-year warranty
16 TB
SAS 12Gb/s
Buffer Size
256 MB
