Seagate has purpose-built the Laptop Thin HDD to meet the customers' demand for affordable, slimmer, fully functional computing solutions.
Smooth migration to advanced format 4K
Laptop Thin HDDs include Seagate SmartAlign technology. This innovation provides easy access to all the benefits of the Advanced Format 4K sector standard - no utilities, no extra steps. AF drive migration happens automatically in the background. The drive's performance is not affected, and there is no need for the time-consuming utilities that are required by other AF-enabled drives.
Enter Seagate ingenuity
Seagate Laptop Thin HDD drives leverage current laptop drives in both material and product design to provide the world's first 7 mm 2.5-inch form factor drive. The result is affordable, thin storage for entry-level to mainstream laptops, high-end netbooks, thin ultraportables and slim-computing devices.
Seagate Laptop Thin HDD ST500LM021 - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
QuietStep, Ramp Load
70.1 mm x 100.55 mm x 7 mm
95 g
Microsoft Certification
Compatible with Windows 7
500 GB
2.5"
SATA 6Gb/s
Buffer Size
32 MB
Bytes per Sector
4096
70.1 mm
100.55 mm
7 mm
95 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
135 MBps
Seek Time
11 ms (average)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.8 Watt (active) , 0.65 Watt (idle)
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
