With a generous 3 TB capacity, this Seagate SkyHawk Surveillance HDD offers ample space for storing large volumes of data, making it ideal for surveillance systems that require extensive video storage capabilities.
Durable design
Engineered for high-load cycles, the hard drive boasts 300,000 load/unload cycles, ensuring reliability and durability for continuous operation in demanding environments.
Efficient performance
Featuring a fast data transfer rate of 600 MB/s and an internal data rate of 180 MB/s, this HDD ensures swift read/write speeds, enhancing the efficiency of surveillance operations.
Optimized for surveillance
Equipped with ImagePerfect firmware, the Seagate SkyHawk is specifically designed to minimize frame loss and ensure smooth video streaming, making it compatible with a wide range of surveillance systems.
Energy-conscious operation
With power consumption modes optimized for surveillance applications, including active, idle, sleep, and standby modes, this HDD balances performance with energy efficiency, reducing operational costs.
Seagate SkyHawk Surveillance HDD ST3000VX009 - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Surveillance system compatible, ImagePerfect firmware
101.85 mm x 146.99 mm x 20.2 mm
490 g
3-year warranty
3 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
